Old 07-16-2011, 06:26 AM
Papy Papy is offline
Default Mack LRVSW
Sorry, just did not notice the server change, so have to re-post here
I started this project long ago to match my 88-B shovel.
The LRVSW is a direct ancestor to the famous M series off-highway trucks (see IHBUILDER M75-SX)
Comparing a Tamiya standard axle to the modified one I will use gives you an idea of the size of this baby (they are supposed to be same scale !)
The LRVSW was basically designed to be a dumptruck, but some of them have been used as logging trucks. Eventually, a couple were later transformed to be used as prime movers for heavy haulage work....
The model will be around 10kg empty (22 lbs) and will have a GVW of 21 kg (46 lbs).
I will have to fill the tires with some serious foam, as the original material is intended for lighter models and is a bit too soft.
Not sure I will keep the Tamiya gear box, but in that case, I will certainly add a 3 or 4:1 reduction gear.
