Old 05-11-2013, 05:43 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
Default Re: Day Cab Work Truck by Izzy
sorry claus - gonna have to wait a little while longer - went to take a photo of her all dressed up and the camera battery died...... maybe she's tired of having her picture taken?????
Old 05-11-2013, 05:52 PM
Claus's Avatar
Claus Claus is offline
That ain't right.
Old 05-19-2013, 04:47 PM
CustomRCmodels's Avatar
Originally Posted by Izzy View Post
the diffs did seems to have a little bit of gear mesh issue - didn't tkae em apart to investigate - .
Chris ,
I do have the same axles ,
just loosen up the diff covers ,
then pay close attention to which screw of the diff-covers is right in the center of the axle , loosen that screw , use a short one or add a washer .
(Wild)-Willy
CustomRCmodels
Old 05-19-2013, 04:57 PM
I can take a vid I suppose ...... Claus - Ive been thinking about those mud grips myself....
but I have a bit more to show in the pics I've already taken ..... anybody notice the cables coming from the diff's??????
works great! I only need 1/2 the throw of the 30mm stroke. I used the lever action since the spring tension the cable is pretty high.....
Chris ,
I reversed the locking action of these axles .
By default they are not locked , the small external spring on that lever has to overcome a coil-spring on the inside .
Means NON-locked , this inside spring is always compressed .
If you remove that spring on the outside lever the axle will be always locked and only unlocked if you pull the lever . I like it that a way much better , the inner spring is not compressed all the time , and it takes a lot less torque now to push/pull that lever for un-locking the axles .
I just gone use a micro-servo above the axles , inside the frame and connect the servo-arm with a small tension-spring to the diff-lever , ( spring = to make up for suspension-travel ) to unlock the axle
(Wild)-Willy
CustomRCmodels
Old 05-20-2013, 12:26 AM
Hey Izzy where did you get that cylinder for your brake setup if i may ask?
Old 05-20-2013, 10:21 AM
Originally Posted by fhhhstix View Post
Nate here are some pics of the deans plug Izzy used. We found it at my local hobby shop but Horizon Hobbies stocks it. The base mount for the plug uses set screws with points on them to secure the plug in the base.
http://www.horizonhobby.com/webapp/w...pe=productgrid
Thanks Travis. I managed to find some online too. Pretty cool mounts. Might have to pick some up.
Old 05-20-2013, 06:48 PM
Izzy's Avatar
Backyard enginier
Seedy8305 - look up firgelli on the web - it's operating the lockers on the duffs
Old 06-04-2014, 10:08 PM
Izzy's Avatar
Backyard enginier
Hello everyone = a little update ....... Aug 2012 or so I dropped the gear set out of the trans on a full pull on the sled at Indy. SO I purchased bevel cut brass gears. Then after a year and half of putting her through some **** and such I dusted off the grime and took her up to the mid Michigan group event last month. Funny thing happened - she wouldn't back up in first gear - 2nd ok and 3rd but not first. Determined on tear down that the "knobs" on the shift plates wore off the plastic trans parts - probably due to the brass gears,
Soooooo
Metal shift plates and a new case for the trans - had been way to hacked up to put back in
Old 06-04-2014, 10:09 PM
Izzy's Avatar
Backyard enginier
add a few shots of other little updates when I had her on the bench .... and some photos of other details
Old 06-04-2014, 11:36 PM
dabears's Avatar
dabears dabears is offline
Well if you blow a trans now you are really trying to do too much with it!! Looks great!
Old 06-04-2014, 11:44 PM
Nice upgrades! Been wondering about those gear sets for the transmissions and what people thought of them. I can't believe you actually wrecked a gear in the stock transmission. Did you always run a brushless out-runner? That's probably why. I see a planetary reducer on the input too. That has to be powerhouse.
Old 06-05-2014, 12:44 AM
Gorgeous Nice decal and paint work, sharp lines!
Old 06-05-2014, 10:05 AM
lukewmc lukewmc is offline
lukewmc is on a distinguished road
Hey Izzy! Truck looks good!
How is that rear suspension still holding up and performing? Any issues with the plastic springs?
Old 06-05-2014, 11:24 AM
avel avel is offline
Is that a custom mount for the outrunner motor?
Old 06-05-2014, 12:13 PM
Bepo Bepo is offline
Bepo is on a distinguished road
wonderful good. Giuseppe
Old 06-05-2014, 07:25 PM
Looks great Izzy keep up the good work.
There are no decals on the truck it is all paint and the guy who did the paint work is a sick individual, no air brush he did it all with a full size automotive paint gun. He is not cheap but you can't beat the quality.
Here are two build threads on trucks he painted as well
http://rctruckandconstruction.com/showthread.php?t=349
http://rctruckandconstruction.com/showthread.php?t=984
Travis
Old 06-05-2014, 09:05 PM
Lmackattack's Avatar
Truck looks great with the added details cant wait to see it next week.
Old 06-06-2014, 02:02 AM
Izzy's Avatar
Backyard enginier
That gear reduction came factory made - had to turn fown the output shaft to fit the helical pinion though.
I like the helical gears - nice bling - joe and others have shown that a stock transmission is plenty strong and durable. No need to do what I have done - even with an out runner. It all domes down to how you drive.
Old 06-06-2014, 07:00 AM
4X44DAD 4X44DAD is offline
4X44DAD is on a distinguished road
looks great keep up the good work
Old 02-21-2016, 02:53 AM
Claus's Avatar
How is the truck running these days Chris? It's a beautiful rig. Curious who made your gorgeous grille?
