Old 07-16-2014, 05:41 PM
Steve1503 Steve1503 is offline
Steve1503 is on a distinguished road
Default Re: Mack R model ten wheeler dump
very nice.
Old 08-25-2014, 07:48 AM
Mikem Mikem is offline
Hi Lmackattack I'm trying to figure out when you said you moved the front axle forward , did you just slip it forward on the spring or get shorter springs and remount them ? BTW I got my Mack cab and it looks good . The only other thing is how did you lock your rear axle . Thanks Mike
Old 08-26-2014, 06:29 PM
Lmackattack's Avatar
I missed Indy so I had to get a quick Fix today to hold me over to the next meet
https://www.youtube.com/watch?v=QS5L...ature=youtu.be
Old 08-26-2014, 06:40 PM
Hi Mike sorry I missed your question
To move the front axel simply move it ahead of the rivet and lock it down. I use the stock springs with just a single leaf. I remove the 2 helper springs so I get more articulation. you may have to do some adjusting after the cab is mounted where you want it.
to lock in the axel in you need to remove the axel(s) from the truck then take the diff out. take the diff halves apart and inside you will see a triangle that holds the 3 sun gears rotate on. take one of the 3 sun gears off the triangle and place it between the other 2 sun gears. now bolt the halves together and it will be fully locked.
Personally I like both axels lock in but I do mostly extreme off roading with my trucks.
Old 08-26-2014, 10:26 PM
Hi again Lmackattack thank for the info . I forgot 1question ,I got my 3d cad how did you get yours smooth ? Thanks Mike
Old 08-26-2014, 11:03 PM
Buy the high build primer at the auto parts store. 3 or 4 coats and let dry A few days between coats. The paint really soaks in to this 3d plastic.
Old 08-27-2014, 08:56 PM
Thanks I will go out tomorrow and get some . Mike
Old 08-31-2014, 04:16 PM
Hi Lmackattack how did you do the motor gearbox / servo , for me one is in the way of the other . Do you have more pics ? Suggestions ? Thanks Mike
Old 08-31-2014, 04:55 PM
bigford's Avatar
bigford bigford is offline
you might possibly want to start your own build thread
Old 09-01-2014, 01:15 AM
I will get some pics of the under side. I used low pro servos and then moved the motor/gear box forward so that the motor sits over the servos.
I shortened the shift control rod its only about 1/2" or a total of 1" long with the plastic rod ends.
The steering servo was flipped around and I ran the control rod between the frame rail and the spring.
Its all a tight fit but works pretty good.
Old 09-01-2014, 03:21 PM
tracksntreadslou's Avatar
My favorite mack cab style..Tough trucks and still see these around on a daily basis...You done an awsome job with this one ..On my bucket list too ..good work buddy
Old 11-01-2015, 07:08 AM
diddys trucking's Avatar
diddys trucking diddys trucking is offline
diddys trucking is on a distinguished road
Please can you tell me where did you get the Mack badges from ?
Old 11-01-2015, 04:20 PM
They are sold as 1/24 etched metal badges but they are way to large for 1/24 the fit the 1/16 much better.
http://www.auslowe.com.au/index.php?...id=2&Itemid=27
MACK
"The Greatest Name in Trucks"
Old 11-01-2015, 07:09 PM
Exclusive RC has them as well
Not trolling anymore...
Old 01-18-2018, 01:32 AM
I installed some of RCP beams in the Mack tonight. It was said on his youtube vid that installing them may limit the side to side articulation slightly. However this truck saw lots of abuse in the dirt over the years and has sloppy pivot points in the suspension. The new beams went in and the slop allowed them to move around quite well. I did run a quick file thru the bottom 2 holes to "oval" them just a little so that each corner of the tandem can move more independently. Both axles have the stock plastic travel stops cut off them and the suspension moves plenty. These will also keep traction even across the tandems being that its now a true center point suspension . I removed the shocks as well to get just a little more travel. doing so I needed to install a RC4WD driveshaft as the tamiya dog bone will not allow for the extra travel it has now
MACK
Old 01-18-2018, 05:26 AM
Looks good!
Old 01-18-2018, 11:54 AM
Giuseppe's Avatar
Giuseppe Giuseppe is offline
Giuseppe is on a distinguished road
Originally Posted by Lmackattack View Post
I bought the mack cab 2nd hand. Not sure where it was made. Im impressed with it.The lift might be a knock off by lesu...i got it on ebay from joes ...it works nice and smooth and seams suited better suited for short box 6 or 10 wheeler end dumps. When installing You have to find the "sweet spot" in the frame to bolt it in. Bolted in To far forward it will not lift the box very high. To far rearward and I question the strain it would see trying to lift the load. I mounted mine between the axels to get good hight and good leverage. Where it's mounted it sits about 15mm above the frame rail so that it clears the axels and allows them to articulate? This is ok because the tires will extend about 5 mm above the rails. Here are some pics focust on the lift.
Hello i added,a spring of about 20mmx10mm,to the output of the geared motor.....it helps lifting
Old 01-18-2018, 07:54 PM
I like your choice in trucks , you did a great job on it.
