Old 08-31-2014, 04:16 PM
Mikem Mikem is offline
Default Re: Mack R model ten wheeler dump
Hi Lmackattack how did you do the motor gearbox / servo , for me one is in the way of the other . Do you have more pics ? Suggestions ? Thanks Mike
Old 08-31-2014, 04:55 PM
bigford's Avatar
bigford bigford is offline
you might possibly want to start your own build thread
Old 09-01-2014, 01:15 AM
Lmackattack's Avatar
I will get some pics of the under side. I used low pro servos and then moved the motor/gear box forward so that the motor sits over the servos.
I shortened the shift control rod its only about 1/2" or a total of 1" long with the plastic rod ends.
The steering servo was flipped around and I ran the control rod between the frame rail and the spring.
Its all a tight fit but works pretty good.
