#81
very nice.
#82
Hi Lmackattack I'm trying to figure out when you said you moved the front axle forward , did you just slip it forward on the spring or get shorter springs and remount them ? BTW I got my Mack cab and it looks good . The only other thing is how did you lock your rear axle . Thanks Mike
#83
I missed Indy so I had to get a quick Fix today to hold me over to the next meet
https://www.youtube.com/watch?v=QS5L...ature=youtu.be |
#84
To move the front axel simply move it ahead of the rivet and lock it down. I use the stock springs with just a single leaf. I remove the 2 helper springs so I get more articulation. you may have to do some adjusting after the cab is mounted where you want it. to lock in the axel in you need to remove the axel(s) from the truck then take the diff out. take the diff halves apart and inside you will see a triangle that holds the 3 sun gears rotate on. take one of the 3 sun gears off the triangle and place it between the other 2 sun gears. now bolt the halves together and it will be fully locked. Personally I like both axels lock in but I do mostly extreme off roading with my trucks. |
#85
Hi again Lmackattack thank for the info . I forgot 1question ,I got my 3d cad how did you get yours smooth ? Thanks Mike
#86
Buy the high build primer at the auto parts store. 3 or 4 coats and let dry A few days between coats. The paint really soaks in to this 3d plastic.
#87
Thanks I will go out tomorrow and get some . Mike
#88
Hi Lmackattack how did you do the motor gearbox / servo , for me one is in the way of the other . Do you have more pics ? Suggestions ? Thanks Mike
#89
you might possibly want to start your own build thread
#90
I will get some pics of the under side. I used low pro servos and then moved the motor/gear box forward so that the motor sits over the servos. I shortened the shift control rod its only about 1/2" or a total of 1" long with the plastic rod ends. The steering servo was flipped around and I ran the control rod between the frame rail and the spring. Its all a tight fit but works pretty good. |
#91
My favorite mack cab style..Tough trucks and still see these around on a daily basis...You done an awsome job with this one ..On my bucket list too ..good work buddy
#92
Please can you tell me where did you get the Mack badges from ?
#93
http://www.auslowe.com.au/index.php?...id=2&Itemid=27
MACK
"The Greatest Name in Trucks" |
#94
Exclusive RC has them as well
Not trolling anymore... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#95
I installed some of RCP beams in the Mack tonight. It was said on his youtube vid that installing them may limit the side to side articulation slightly. However this truck saw lots of abuse in the dirt over the years and has sloppy pivot points in the suspension. The new beams went in and the slop allowed them to move around quite well. I did run a quick file thru the bottom 2 holes to "oval" them just a little so that each corner of the tandem can move more independently. Both axles have the stock plastic travel stops cut off them and the suspension moves plenty. These will also keep traction even across the tandems being that its now a true center point suspension . I removed the shocks as well to get just a little more travel. doing so I needed to install a RC4WD driveshaft as the tamiya dog bone will not allow for the extra travel it has now
MACK
"The Greatest Name in Trucks" Last edited by Lmackattack; 01-18-2018 at 01:34 AM. |
#96
Looks good!
#97
#98
I like your choice in trucks , you did a great job on it.
