Old 07-10-2017, 12:47 AM
Default Re: Volvo A40F
Hey awesome work!! Really!! Do you have a vacuum table? I see the mat material and I know one of the companies uses that material for vacuum fixtuerimg. If so do you like it? Been debating on vacuum vs outsourcing flat parts. Double sided tape has been working but pita to remove!!
Yes I have a vacuum table and at it's best it is great. But when machining a thin materials the mill cutter tends to lift the plate and then it comes loose. By hand you can't move the plate you are machining sideways, but when you lift a corner it's quite easy to detach. I usually run in to problems with under 1mm thicknesses.
Old 07-10-2017, 07:09 PM
Cooper's Avatar
Cooper Cooper is offline
Understand, been using wax and that has lifted a couple times also. Went back to using double sided tape. It's a lot more clean up on table plate and part but haven't had any lifting .
Glad you brought up the turning forces, I would have never thought of sidewall forces under sharp turns. Really great work your doing!!
Old 12-06-2017, 04:24 PM
rc entreprenøren rc entreprenøren is offline
rc entreprenøren is on a distinguished road
Originally Posted by Hemi1966 View Post
More steps
Does anyone New where to by this plates Ari uses for steps. This steps with round Hols in.
Old 12-06-2017, 04:51 PM
trucker n's Avatar
He makes them
Old 12-06-2017, 05:03 PM
Originally Posted by trucker n View Post
He makes them
Are sure of this...its looks very god...
Old 12-06-2017, 07:44 PM
Nice work , have to admire the talent you guys have who build these machines.
Old 12-06-2017, 07:59 PM
Northern Farmer's Avatar
Check on ebay or google for hobby perforated brass plate.
Old 12-06-2017, 10:28 PM
I did not find plates like that anywhere, so I indeed made them
Old 12-07-2017, 10:54 AM
Ok. Beatyfull work Innedid.
Ari do you now.
I havet baught the dozer that Unix on this forum ha made.
I planting to powdercoat the parts. But the brass is souldered together. Parts are from 1 mm to 3mm souldered together. Do you think It Will go ok.?? At 190 degrees. For 20 minutes.
Old 12-09-2017, 01:07 AM
Ari do you now.
I think normal solder melting point is about the same, so you have a risk of melting joints.
Old 12-09-2017, 01:31 AM
I got the first 3D print of the bonnet from my buddy Steve. It turn out nicely, all though it is actually a test print to see how it fits to the rest of the machine.
It needs some small adjustments and after that I think it's going to be perfect
Old 12-09-2017, 04:28 AM
That's an AWESOME looking truck you're building!
Old 12-10-2017, 09:11 AM
Hofabooz's Avatar
Hofabooz Hofabooz is offline
Hi Hemi
Looking great the 3D print complements the machine perfectly nice work.
Looking for forwards to seeing this work progress..
Regards
Mark
Over the Pond in the UK
Member of Ribble Valley Radio Controlled Truck Club
my weather station
Old 12-10-2017, 02:56 PM
TRUCKMAKER's Avatar
Looks real good Ari, the hood turned out nice and should finish off perfect!
Old 12-25-2017, 03:13 PM
Snochaser's Avatar
Can’t wait to see this completed Ari.
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 12-26-2017, 10:35 AM
How much time did it take to get that hood so smooth ?
Old 12-31-2017, 12:18 AM
Smile Re: Volvo A40F
This is the latest fixed size bonnet, it took 35 hours to print
Thank you for that Steve
Old 12-31-2017, 01:24 AM
D@M! That's a marathon print job there. It looks nice.
Old 12-31-2017, 07:11 PM
What is the difference between this new hood and the other one ?
Old 12-31-2017, 11:42 PM
The first one was too wide and too short.
