RCP’s Aluminum Gravel Boxes and Accessories Welded aluminum dump boxes and more |
#141
Hello I would like to know if you have any dump trailers for sell ? If so do you have pitures of them where I can see
#142
Reg |
#143
It's as asphault apron, it prevents the hot mix from damaging the rear of teh truck while dumping into the paving hopper. we use those a LOT here in Washington state for our paving projects. Ours have rubber sides, instead of metal, so they will flex a bit, if they encounter an obstacle, rather then tear up the apron.
#144
During this winter, since it'll slow down for us that work for companies that primarily pave, in WA state, I plan to build a King hauler, & customize it to a dump truck. What would be the cost, to have you fab a dump bed that's a SUPER SOLO box? I'd like said box to be equipped with hydraulic arms for the rear Axle, AKA MAXLE, &/or STRONG ARM, depending what company manufactured it.
Here in Washington State, we can legally gross 82,000 on 7 axle super dumps, versus the 65,500 with a conventional 3 axle truck. The alternative, 105,500 with a truck & pup combination that has 8 axles, netting around 32ish tons of product. Since the SUPER DUMPS can generally net 24-25ish tons of product, NOT have to drop & hook a trailer each round to dump asphalt into the paver, & can do 3 round trips to the truck & pup's 2 rounds, they make sense for companies here. |
#145
I can send pictures, & measurements, if you need them for the build
#146
The 3 axle trucks can net, legally between 14.75-16 tons, depending upon the tare weight. I forgot to put that into the comparison above.
#147
I just looked at a few pictures of this contraption and it's definitely complicated. I'm not sure if I would even want to tackle it honestly as it looks like it would take a ton of hours to get it all working. I think finding a dollar figure that made us both happy would be difficult on this one. It would be a one of a kind build though that's for sure.
#148
#149
I DON'T have the appropriate tools to do that kind of work. I WISH I had the room to stuff COOL tools like brakes, rollers, lathe, CNC, & a welder that is capable of welding aluminum, but I just don't have room in the tiny garage space I have. If I had a welder capable of welding on aluminum, I might could try my hand at it, but I don't. |
#150
http://www.youtube.com/watch?v=eVVZj-qnx1A |
#151
The drive for the trailer chain could be driven via a servo, much like you Bruder D11 Cat conversion.
Either the transfer trailer, & CUSTOM Trk box to match it, or the SUPER DUMP, I'd be highly interested in, as I drive both, depending the day &/or job we will be doing that shift. I also drive the 7, &/or 8 axle Trk & pup combinations, as well depending the jobsite we are working at. Occasionally some Side dump work is in my week too. |
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
Thread Tools | |
Display Modes | |
