RCP’s Aluminum Gravel Boxes and Accessories Welded aluminum dump boxes and more |
What's the purpose of the spill plate?... hauling moist dirt, it'll interfere with the tailgate closing & the door won't lock
It's not something you see here very often on real trucks. I'm not sure what it's really needed for, I just try to build what I'm asked. It looks like something that would get bent or torn off on a 1:1 in this area but we don't have drop axles or any of that stuff either. Just good old tandem dump trucks....Most of which look well used within a very short time.lol
The spill plate is mostly used for asphalt when backed up to a paving machine,
preventing asphalt from flowing over the hopper in front of the paving machine when tipping. And it protect the rear end of the truck, mud flaps and lights. ![]() |
That makes sense. The last truck I noticed one on was dumping asphalt into a hopper on the paving machine. I see lots of trailers have them and I assumed it was to protect the goodies on the back since they are so flat on the rear panel. Tail lights right below the tailgate without protection not good one...
Yes Reg.
I got to have one of that Dump Body.............Ooh no two body's for truck & Trailer. Thinking i don't got a dump of any kind so it's a must have.......going to Marios so you got time to build them......i hope ? ![]() ![]() |
I'll make time! Want it next week?lol Hey do you want a pup trailer? It's already built and I'll give you a good deal!
It's as asphault apron, it prevents the hot mix from damaging the rear of teh truck while dumping into the paving hopper. we use those a LOT here in Washington state for our paving projects. Ours have rubber sides, instead of metal, so they will flex a bit, if they encounter an obstacle, rather then tear up the apron.
I can send pictures, & measurements, if you need them for the build
The 3 axle trucks can net, legally between 14.75-16 tons, depending upon the tare weight. I forgot to put that into the comparison above.
I just looked at a few pictures of this contraption and it's definitely complicated. I'm not sure if I would even want to tackle it honestly as it looks like it would take a ton of hours to get it all working. I think finding a dollar figure that made us both happy would be difficult on this one. It would be a one of a kind build though that's for sure.
I DON'T have the appropriate tools to do that kind of work. I WISH I had the room to stuff COOL tools like brakes, rollers, lathe, CNC, & a welder that is capable of welding aluminum, but I just don't have room in the tiny garage space I have. If I had a welder capable of welding on aluminum, I might could try my hand at it, but I don't. |
http://www.youtube.com/watch?v=eVVZj-qnx1A |
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
