#261
#262
Understand, been using wax and that has lifted a couple times also. Went back to using double sided tape. It's a lot more clean up on table plate and part but haven't had any lifting
![]() Glad you brought up the turning forces, I would have never thought of sidewall forces under sharp turns. Really great work your doing!!
#263
Does anyone New where to by this plates Ari uses for steps. This steps with round Hols in.
#264
He makes them
#265
#266
Nice work , have to admire the talent you guys have who build these machines.
#267
Check on ebay or google for hobby perforated brass plate.
#268
I did not find plates like that anywhere, so I indeed made them
#269
Ok. Beatyfull work Innedid.
Ari do you now. I havet baught the dozer that Unix on this forum ha made. I planting to powdercoat the parts. But the brass is souldered together. Parts are from 1 mm to 3mm souldered together. Do you think It Will go ok.?? At 190 degrees. For 20 minutes. |
#270
#271
I got the first 3D print of the bonnet from my buddy Steve. It turn out nicely, all though it is actually a test print to see how it fits to the rest of the machine.
It needs some small adjustments and after that I think it's going to be perfect ![]() ![]() ![]() ![]()
#272
That's an AWESOME looking truck you're building!
#273
Hi Hemi
Looking great the 3D print complements the machine perfectly nice work. Looking for forwards to seeing this work progress..
Regards Mark Over the Pond in the UK Member of Ribble Valley Radio Controlled Truck Club my weather station To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#274
Looks real good Ari, the hood turned out nice and should finish off perfect!
#275
Can’t wait to see this completed Ari.
#276
How much time did it take to get that hood so smooth ?
#277
#278
D@M! That's a marathon print job there. It looks nice.
#279
What is the difference between this new hood and the other one ?
#280
The first one was too wide and too short.
