Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
#381
Wowzers! 4 of the big donnagers, you'll be doing some serious winching with them.
IDK how well the motors work....yet. I have them bolted onto the Bruder D11 conversion. EVENTUALLY, I'll get that project off my project bench(ES) & get it working. BIGFORD I'm GLAD to hear that they are trouble free motors. BO, THANKS fir the tip. I hadn't thought to open them to look. I definitely will be checking them, BEFORE placing the machine into service! Last edited by skeeter; 02-06-2018 at 05:27 PM. Reason: typos |
#382
Interesting truck indeed.
Can you lay a rule or caliper on those right angle motors? I've been hunting for a pair but they cant be any more than 40mm wide when placed back to back to fit down into my little project I was foolin with. |
#383
Opsi.....Opsi Didn't tell you all of it....Did i ?
![]() [IMG] ![]() Two winches forward. Two Backwards. and two awkward.... ![]() P.S. Steve /9W Monighan i will do that pronto ![]() Last edited by Bo Wallen; 04-23-2018 at 10:28 AM. |
#385
Looks like motor is out some from the back of case making them not touch each other. Whats the link to get some of these?
#386
They are out of stock right now. I got a mail stated back in stock February 15 2018 So there is hope for us. |
#387
#388
Need Road Construction Machine for Beam Hauler Fleete. So i started one more project..........Could be Ford's first Grader who knows.
[IMG] ![]() [IMG] ![]() Last edited by Bo Wallen; 04-23-2018 at 10:28 AM. |
#389
Very nice.
#390
CTI actuators? Gear motor on each wheel?
#391
Thanks ittigger ;o)
Now that's a very good question........wish i had a good answer to give. I like the CTI actuators, so i'm trying them. i also looking if there could be a hydraulic alternative. Drive motors might go in the wheels.......i got to ask how you like the ones in your haul trucks. I'll make the front part of the frame in steel sheets for adding weight and strength....thinking i'll pop a line of battery cells inside.......not much room for things. |
#392
Nice one Bo! Ive always loved graders. Not enough around!
#393
Don't need the power of hyds for this type of machine & the CTI's will save you so much space. Do they each require an esc to operate? Maybe the actuonix would simply things even more
![]() The brushed motors work great & only need one esc to run 4 motors. The rpm on 3s is about 110. The brushless ones each need an esc for each motor & travel 10-15% slower, more expensive too, a bit shorter in length.
#394
Thanks Hostile.
Yes a grader is No 1 on my list for sure. a Ford might be outside the box......but i was outside the box all my life so i go with that........a different machine mathers too ;o) |
#395
Good ideas / advice right there. I need a lot of power and low speed when grading or push with front blade or ripper in the rear. Have to do some torque test, it's a bit of dozer power needed to the wheels. I had one idea that required the hood to be extended a bit in length. a two speed gearbox and chain drive between the wheels like the real ones. well back at it and we see..... |
#396
Getting the Globe in to a multi tool. Beam Haule/Push Pull truck.
[IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() Near ready for paint and Bling stuff. Last edited by Bo Wallen; 04-23-2018 at 10:27 AM. |
#397
Be aware, making "multi-trucks" might lead to the need to downsize the overall fleet
#398
![]() ![]() Did you try the frame rails yet ??? |
#399
When would anyone have to many trucks ? Baffling
#400
No, been to the US once more since we met. No time for hobbies for awhile.
Thread Tools | |
Display Modes | |
