Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
Don't need the power of hyds for this type of machine & the CTI's will save you so much space. Do they each require an esc to operate? Maybe the actuonix would simply things even more
![]() The brushed motors work great & only need one esc to run 4 motors. The rpm on 3s is about 110. The brushless ones each need an esc for each motor & travel 10-15% slower, more expensive too, a bit shorter in length.
Good ideas / advice right there. I need a lot of power and low speed when grading or push with front blade or ripper in the rear. Have to do some torque test, it's a bit of dozer power needed to the wheels. I had one idea that required the hood to be extended a bit in length. a two speed gearbox and chain drive between the wheels like the real ones. well back at it and we see..... |
Getting the Globe in to a multi tool. Beam Haule/Push Pull truck.
[IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() Near ready for paint and Bling stuff. Last edited by Bo Wallen; 04-23-2018 at 10:27 AM. |
Currently Active Users Viewing This Thread: 21 (0 members and 21 guests) | |
