Old 02-06-2018, 04:37 PM
Default Re: KH Beam Hauler
Wowzers! 4 of the big donnagers, you'll be doing some serious winching with them.
IDK how well the motors work....yet. I have them bolted onto the Bruder D11 conversion. EVENTUALLY, I'll get that project off my project bench(ES) & get it working.
BIGFORD I'm GLAD to hear that they are trouble free motors.
BO, THANKS fir the tip. I hadn't thought to open them to look. I definitely will be checking them, BEFORE placing the machine into service!
Old 02-06-2018, 05:27 PM
Interesting truck indeed.
Can you lay a rule or caliper on those right angle motors? I've been hunting
for a pair but they cant be any more than 40mm wide when placed back to back to fit down into my little project I was foolin with.
Old 02-06-2018, 05:58 PM
Bo Wallen's Avatar
Exclamation Re: KH Beam Hauler
Opsi.....Opsi Didn't tell you all of it....Did i ?
[IMG]IMG_2174 by Bo Wallen, on Flickr[/IMG]
Two winches forward. Two Backwards. and two awkward....
P.S. Steve /9W Monighan i will do that pronto
Old 02-06-2018, 06:13 PM
Bo Wallen's Avatar
Lightbulb Re: KH Beam Hauler
Steve here is two shot's hope it's good enough.
[IMG]IMG_2175 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_2176 by Bo Wallen, on Flickr[/IMG]
The shaft protrude 17mm and is 6 mm d shaft
Old 02-06-2018, 06:25 PM
Looks like motor is out some from the back of case making them not touch each other. Whats the link to get some of these?
Old 02-06-2018, 06:30 PM
Bo Wallen's Avatar
https://www.robotshop.com/en/6vdc-40...ear-motor.html
They are out of stock right now. I got a mail stated back in stock February 15 2018 So there is hope for us.
Old 02-06-2018, 06:41 PM
Thanks Bo
Old 03-08-2018, 12:26 PM
Bo Wallen's Avatar
Need Road Construction Machine for Beam Hauler Fleete. So i started one more project..........Could be Ford's first Grader who knows.
[IMG]IMG_2286 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_2284 by Bo Wallen, on Flickr[/IMG]
Old 03-08-2018, 01:13 PM
ittigger ittigger is offline
ittigger is on a distinguished road
Very nice.
Old 03-08-2018, 02:57 PM
CTI actuators? Gear motor on each wheel?
Old 03-08-2018, 03:14 PM
Bo Wallen's Avatar
Originally Posted by ittigger View Post
Very nice.
Thanks ittigger ;o)
Now that's a very good question........wish i had a good answer to give. I like the CTI actuators, so i'm trying them. i also looking if there could be a hydraulic alternative. Drive motors might go in the wheels.......i got to ask how you like the ones in your haul trucks. I'll make the front part of the frame in steel sheets for adding weight and strength....thinking i'll pop a line of battery cells inside.......not much room for things.
Old 03-08-2018, 03:47 PM
Hostile Hostile is offline
Hostile is on a distinguished road
Nice one Bo! Ive always loved graders. Not enough around!
Old 03-08-2018, 04:45 PM
Don't need the power of hyds for this type of machine & the CTI's will save you so much space. Do they each require an esc to operate? Maybe the actuonix would simply things even more
The brushed motors work great & only need one esc to run 4 motors. The rpm on 3s is about 110. The brushless ones each need an esc for each motor & travel 10-15% slower, more expensive too, a bit shorter in length.
Old 03-08-2018, 07:46 PM
Bo Wallen's Avatar
Thanks Hostile.
Yes a grader is No 1 on my list for sure. a Ford might be outside the box......but i was outside the box all my life so i go with that........a different machine mathers too ;o)
Old 03-08-2018, 08:00 PM
Bo Wallen's Avatar
Thanks Joe.
Good ideas / advice right there. I need a lot of power and low speed when grading or push with front blade or ripper in the rear. Have to do some torque test, it's a bit of dozer power needed to the wheels. I had one idea that required the hood to be extended a bit in length. a two speed gearbox and chain drive between the wheels like the real ones. well back at it and we see.....
Old 03-31-2018, 06:39 PM
Bo Wallen's Avatar
Getting the Globe in to a multi tool. Beam Haule/Push Pull truck.
[IMG]IMG_2305 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_2306 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_2303 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_2476 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_2475 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_2474 by Bo Wallen, on Flickr[/IMG]
Near ready for paint and Bling stuff.
Old 04-01-2018, 01:18 AM
Be aware, making "multi-trucks" might lead to the need to downsize the overall fleet
Old 04-01-2018, 09:28 AM
Bo Wallen's Avatar
Talking Re: KH Beam Hauler
Ops ! did not think of that............ Must find a solution of that............
Did you try the frame rails yet ???
Old 04-01-2018, 02:58 PM
Mikem Mikem is offline
When would anyone have to many trucks ? Baffling
Old 04-01-2018, 03:38 PM
No, been to the US once more since we met. No time for hobbies for awhile.
Currently Active Users Viewing This Thread: 14 (0 members and 14 guests)
