Old 04-15-2020, 09:42 AM
Default Re: HIAB X-HIPRO 1058 loader crane
I got rest of the pins done
Old 04-15-2020, 01:50 PM
crueby crueby is offline
crueby is on a distinguished road
Sorry if I missed it from earlier, but what is the function of the elongated plates on the pins?
Old 04-15-2020, 10:53 PM
If you mean these, here's the explanation:
Old 04-16-2020, 06:24 AM
Looks very nice!
Mount it to your workbench and use it as your shop crane!
Old 04-16-2020, 11:27 AM
Originally Posted by Azonic View Post
Looks very nice!
Old 04-16-2020, 11:31 AM
First extension done
I also made two lifting eyes
Old 04-17-2020, 10:41 AM
Second extension done
Everything just tack welded. I will made all the extensions, and if all looks fine, I'll weld them completely.
Old 04-19-2020, 09:14 AM
I've been drawing the extension boom and I got most of the main parts drawn.
I know it's going to be challenging to route all the hydraulic lines to the cylinders
Old 04-19-2020, 01:32 PM
Hi Ari,
Actually it is these plates I was wondering about:
The normal round ones would act as bushings/bearings, I think, but I dont understand why some of them are oblong with that extra bolt in them.
Old 04-20-2020, 12:07 PM
Trucker47's Avatar
Hey Hemi,
Build is top quality as usual! I assume you are using a TIG to weld? If so what thickness is the steel and how many amps are you running?I just picked up a TIG and have lots to learn!
Old 04-20-2020, 12:21 PM
It all comes to that where they like the movement to happen. If the cylinder mounting pin is fixed to the boom, there's a bushing in cylinder where the rotation happens. With those freely floating pins, I guess there's bushings in all of the joints.
Old 04-20-2020, 12:40 PM
Originally Posted by Trucker47 View Post
Hey Hemi,
I use 2 mm steel on the column and the first boom. The first three telescopes are 1 mm and the rest I will made of 0,5 mm steel.
The Tig welder I have is this one, but an older modell :
https://www.schweisstechnik-lampert....el-making/m280
It does not show the actual amps, just a percent value, so no idea
Old 04-25-2020, 11:56 PM
I studied how they arrange the oil delivery to the extension cylinders on the full size crane, and I realized they come up with a clever solution.
The oil is run trough the piston rod to the next cylinder. There's apparently two holes running all the way inside the rod from each side of the piston and out of the the top of the rod. If you look closely at this picture you'll see what I mean. There's no rubber hoses, just hard lines.
Unfortunately that's not possible to accomplish in this scale, the rod is only 4 mm thick and over 150 mm long. It would have made everything so much tidier
Old 05-02-2020, 11:39 AM
I got all the extensions done
Old 05-17-2020, 12:23 PM
Some progress with the crane
Old 05-17-2020, 03:04 PM
As usual, a most astounding display of craftsmanship! Your welding machine certainly makes putting the pieces together easier and neat. Awesome!
Old 05-24-2020, 10:10 AM
I got the parts for the extension cylinders done. The o-ring grooves on the cap for the piston rod sealing were quite difficult to machine as the hole diameter is only 4 mm. My grooving tools minimum hole size was 4,1 mm, so I had to do some grinding to get it fit.
I also got the rest of the cylinder brackets machined.
Old 05-24-2020, 11:25 AM
Great detail and precision!
Old 05-25-2020, 06:28 PM
I'm loving this project! You are an excellent machinist to make precision parts that small & still be accurate enough to make them function properly!
Old 05-26-2020, 01:21 AM
Beautiful machining, that's coming along great! Touch them with a deburring tool and those cylinder parts are like jewlery.
Any luck on finding the sliding teflon tape, or does it look smooth enough you might not want some?
Post 49, i think the oval bushing plates on the real ones are set up to be either pin-retainers or anti-rotation locks. They usually do step cuts and different sized bushing holes if it's retaining. If it's rotation there's some offset between holes and pin diamater so it clocks the pin in the bore to slow down wear.
Tags
hiab, loader crane
