#241
What would something like this cost to have built?
#242
It's been a long time. I was wondering if there are any updates on project, did you complete it? I watch your latest video almost every day. I wonder if you still have a chance to upload a new video?
Thank you. |
#243
#244
#245
Time to bring out the popcorn again
#246
how's that paladin radio working out? i wanted to get one but ended up adding 4d sticks to my taranis 9e
#247
No complains on the radio, easy to set up and feels sturdy. I really like those side levers, that I use to lift left and right side of the blade on the grader.
#248
Qual a dimensão dos pneus
#249
The wheel diameter is 120mm and the width is 46mm.
#250
Ari To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Hemi1966; 11-07-2021 at 10:31 AM. |
#251
#252
I still have some electronic updates to do. Also while setting up the radio, I found a leak on the blade side shift cylinder hose. I most likely have to change the hole hose, and of course, that's the most hardest one change. ![]() ![]()
#253
Are you using sheet metal option in Fusion 360 to design these parts?
#254
Yes I am.
#255
#256
Those parts are looking awesome! Very nice!
#257
This project is nuts, it just keeps getting more awesome!
Plus that's some pretty sweet looking low profile Tig work. I've got to second Lil Giants question. Videos?
#258
#259
I got the ripper teeth holders done and welded. I also started to make the teeth bodies, the tooth tip is a separate piece.
#260
Beautiful work as always. Are you using a filler wire on your welds or just doing a series of spot welds?
Currently Active Users Viewing This Thread: 25 (0 members and 25 guests) | |
Thread Tools | |
Display Modes | |
