Old 11-13-2021, 12:54 PM
Default Re: CAT 14M3 Motor Grader
Originally Posted by Hemi1966 View Post
No complains on the radio, easy to set up and feels sturdy. I really like those side levers, that I use to lift left and right side of the blade on the grader.
Sounds like you've had some stick time on the grader, where's the videos?!
Old 11-14-2021, 07:06 AM
I still have some electronic updates to do. Also while setting up the radio, I found a leak on the blade side shift cylinder hose. I most likely have to change the hole hose, and of course, that's the most hardest one change.
