#621
wow Joe, This is amazing what you are doing in your basement of all places, it would be awesome to "work" down there.
#622
#623
Lucky guess
#624
So this is what I've been digging lately, under the west porch.. it was kind of a ski slope from the back wall to the water heater. Cutting it down flat, square up the edges, make it a better storage area for wet dirt from other areas in the basement. Took about 12" cut at the face of the wall & it's about 8" at front of cut.
![]() ![]() ![]() ![]() ![]() Hauling the wet dirt over here to the sw corner, will eventually employ bucket screener here & haul the wet lumps back to where I'm digging now, to leave to dry out over summer, then crush it next winter & pile and haul it out summer of '14. ![]() ![]() ![]() This cut is 18" deep by 72"x32" (0.917 cu yd), that's most of the dirt already in this corner. ![]() ![]() There's maybe a dozen bellydump loads to screen & crush here presently, the last of the bone dry dirt from the wall mined away last winter. ![]() Haul quite a bit of this crush over to the wet pile sw corner, give the 850 a dry, elevated platform to perch from while screening. And put the remainder in the wall for backfill. ![]() ![]() Started the slow soak again this morning under the west porch, take about a week for thorough deep coverage, then let the surface dry for about 3 or 4 days & dig some more...starting at 8" at the last cut, tapering down to an inch depth just behind the water heater. ![]() ![]() ![]() Here's a movie, can't see the 850 hardly b/c of poor lighting, but I think you can still make out how tight of area it is for it to work within. ![]() http://youtu.be/WwrxdVTLfmY
#625
Nice Joe, you moved a bunch of dirt, I'm sure you're being cautious around your cast iron sewer. That would be rough if it let go, you'd be doing logging
![]() ![]() Ben
You are an inspiration to many To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , you will not be forgotten. R.I.P. FGD Work Hard, Play Hard! Never Forget- 343 |
#626
I bumped the pipe with the chisel bar a few times when I was digging in the posts for the wall, sounded pretty solid... do they crack easy? what's the wall thickness generally? Should I be covering up the exposed metal surface, pouring oil on it to prevent/slow further rusting?
#627
Wish i could come up and play!! I wanna play in the dirt but cant till spring.... I can move snow though.... HAHA
#628
I'd love to come and play as well, flights from Australia aren't overly cheap though.
#629
#630
Joe, your driving/operating skills make me sick..... You are such a master. That is all!
Ayoub
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. If you got it, a Trucker brought it.... |
#631
Well it's been there nearly 50yrs Steve, good to know thanx.
Practice practice practice Ayoub... time for you to start shining the paint off that new loader of yours & showing us lots of videos, will they let in the building to do some track maintenance? ![]()
#632
how many batteries do you go though in a normal night?
you must have alot of batteries and chargers? the video's are great. buzzy |
#633
Joe is going to be done before I ever get out there! and Im only like a day trip away from him lol!
#634
Joe they do break easy to if you hit them. They get hairline cracks and start seeping. Just be cautious.
#635
Buzzy, might use a lipo or two in a night, depends on hard digging or screening. Trks last for hours on a charge... this winter has been lack of ambition, 3-4 days/wk, 1-3hrs at a time.
Perhaps someday Dean. ![]() Good to know, thanx Ben. ![]()
#636
Very tight spot Joe ..You managed that quite well ..Great vid too ...I find some of the longer say more that 5 minutes gets sometimes boring and i will not watch the whole vid .Not with yours though .the way you split it up doing different things makes a big difference ..Thanks for keeping us in the loop
#637
Thanks for the update Joe
Looks like that WA 500 is still going strong, any idea how many hours you have on it ? greg |
#638
Cheers Lou. Cameras with bigger memory cards nowadays & youtube's wider mb allowance, not so rushed anymore to cram it all together or have to make several vids to tell the whole story.
![]() Don't know Greg, it has worked very well... making a new bucket out of steel right now, the aluminum floor of the old one is getting paper thin & the pivot points quite loose. Also just got a rotary table from Sherline to make some custom wheels to mount different hollow tires that I can add BB's to to get this loader heavier for better traction & lower center of gravity for better stability. ![]()
#639
Buggered on the lighting again... it was much brighter & clearer before uploading to youtube.
![]() http://www.youtube.com/watch?v=_Vg0OXyiQ3w
#640
needs a spotlight aimed where the bucket goes.. those halogen ones from china are great and give off plenty heat as a bonus).
Currently Active Users Viewing This Thread: 75 (0 members and 75 guests) | |
Thread Tools | |
Display Modes | |
