Old 02-06-2013, 05:47 PM
I bumped the pipe with the chisel bar a few times when I was digging in the posts for the wall, sounded pretty solid... do they crack easy? what's the wall thickness generally? Should I be covering up the exposed metal surface, pouring oil on it to prevent/slow further rusting?
Old 02-07-2013, 03:21 AM
yes they do if they're not bedded well . the wall is some where around .1875 - .25 inches . I don't have any here since I haven't put any in in the last few years . Down here it was a common practice to put blocking under the pipe fore setting grade with no bedding under the rest . I've replaced many like that do to the back fill breaking the pipe between the blocking . Yours looks to be bedded well
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
