View Poll Results: Would you buy this if it went into production?
Yes I would buy a metal version 13 34.21%
Yes, but I would like a cheaper plastic version 18 47.37%
No, there are better options out there 7 18.42%
Voters: 38. You may not vote on this poll
Old 06-03-2016, 08:11 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
Default Re: Tamiya bolt on reduction gear
The longer shaft (here) has the benefit of the output on the front of the tranny. It also has the drawback of having the output on the front of the tranny since it is already very tight in stock locations!
Tags
3speed, gearing, reduction, tamiya
