View Poll Results: Would you buy this if it went into production?
Yes I would buy a metal version 13 34.21%
Yes, but I would like a cheaper plastic version 18 47.37%
No, there are better options out there 7 18.42%
Voters: 38. You may not vote on this poll
Old 06-03-2016, 04:35 AM
Doggy's Avatar
Doggy Doggy is offline
Doggy is on a distinguished road
Default Re: Tamiya bolt on reduction gear
My parts ar printed with 100% infill, so are as strong as material it self, and the design is what makes it strong not to snap or wobble. In this case, only thing that needs to be strong are the gears, and after testing them, only way they will fail is if they heat up too much. So they will melt before they snap. And I dont see how much you would have too pull for it to get worm enough to melt.
But I am waiting for a special more expensive material, designed for printing gears, so with that thing, it should be unbreakable. i will have to make few test videos asap.
Old 06-03-2016, 10:40 AM
Claus's Avatar
Claus Claus is offline
Kind of getting off track here, but some of you mentioned using a transferase and running a driveshaft under the 3 speed. We all know there is not much room under that transmission and you have to lift it sky high, I have bought one of these aluminum transmission cases off eBay, they come in different colors and are one piece so the have to ears to screw them together. Maybe not the biggest help but when running a driveshaft under a 3 speed you need all the room you can get.
Old 06-04-2016, 10:27 AM
ihbuilder's Avatar
Hmm, printing gears no tanks unless they're printed on the highest quality professional printer in sintered metal . How are you keeping a tight bearing bore in that printed resolution ? How is it for longevity . IMHO, home printed parts are good for cosmetics , but are prone to failure doo to the porosity in the microscopic structure . Parts machined,injection molded and cast have a consistent grain structure which is paramount in the parts strength . Yes, it looks "strong" with all the bulk around the bearing journals, but is it ? A good well placed single weld bead is in most cases stronger then multiple layered poor weld beads .
In short , I applaud your effort for one self . I would consider a different approach of manufacturing if you plan to sell .
Tags
3speed, gearing, reduction, tamiya
