Old 02-23-2019, 10:07 AM
Default Re: CAT 14M3 Motor Grader
I've been working with the circle gear, and I got it almost machined when it came loose off the chuck. I could not tighten the chuck very tight because the circle gear is not very thick. I was taking very moderate cuts and relatively slow speed, but it was not enough
I have to try again, and do the final operation with different mounting method.
Luckily some parts turn out decently.
