How I'd print the cab would depend on the size of it. IF it was small enough I could get in on my printer in one shot, I'd try it that way first.
That would be the easiest way, I'm just a bit bit worried about how the window openings will turn out.
I made the first side wall for the engine enclosure. It's quite awkward shape as it get wider at half way and the upper front corners are bevelled, due better rear visibility.
ola boa tarde muito impressionante todo seu trabalho eu gostaria de ver um vídeo destas soldas é possível você fazer um vídeo de como você faz estas soldas?
https://www.youtube.com/watch?v=YoXMCrlaGT4
hello Hemi1966
Impressive. Are you soldering aluminum? Does your device have for sale? Where can we buy one of these? Thank you |
