Thanks. I am
![]() ------------- The complicated parts of the front axles needed intensely research and planning time. Enough time for painting. Not my favourite task. But sometimes it has to be ![]() ![]() Bored from painting, i've made the baseplate for the Front (1mm stainless) ![]() ![]() ![]() Planning has closed and the work begins. Milling the Joints from stainless ![]() After some tests about steering radius etc i've to shorten the steering cylinder. So i've take the opportunitiy and build it a bit more scale. later you will see nothing from it, but i know, it's almost scale. ![]() changed cylinder needs a changed flange. from ![]() to ![]() at least mounted and covered from a heavy duty skid plate ![]()
Regards Ralf |
