Looks like you got a Optimum milling machine, is that BF20 ?
Did you cut all the sheet metal parts yourself ? And also, great work ![]()
thanks again.
and yes. i buy simple sheets and cut them self. my tools are a simple lever shear, flex bandsaw, some bender and a old bosch belt sander. I'm a programmer by trade, so i could use a cad and buy laser cutted metal, but i won't work with computers after the whole day on it. ------------------ Last complicated parts are the telescopic lift cylinders. ![]() They are located in the big slots inside the frame. Big? When you plan and estimate the sizes of the cylinder, the slots gets smaller and smaller ![]() Seldom I've planned so long for a single part. Maximum and Minimum Angles, posibilities in machining, needed pressure to lift, sizes of the cylinder, rods and pistons and so. So much interdependent variables. ![]() I'll show you the second and last attempt ![]()
Regards Ralf |
![]() I also have a BF20L that I converted to cnc , and I love it.
Well, after planning, the doing was a simple turning job
the guard rings are very small. ![]() seals are simple o-rings ![]() ![]() big thread on the lid ![]() ![]() ![]() Fits perfect ![]() ![]() ![]() To lock the trough in open state for working on the hydraulics are at the big ones simple Us wich will hook on the back plate. So do i ![]() Works ![]() Here you can see the last part of the cylinder with the flange. both from stainless to be able to weld. All other parts are from aluminium. ![]() the original have a maximum tilt angle of 53°. almost ![]() ![]() later, after some test and measuring, i'm able to raise the size of the guard-rings. that brings a lot more stability.
Regards Ralf Last edited by pufferfish; 01-24-2022 at 02:13 PM. |
Last post so far
![]() The exciting parts are done. Followed by things i have to do. Hydraulic arrangement ![]() Many stainless sheets .3mm or .5 mm are cut, bend and welded to build the front. ![]() The bonnet is parted. ![]() ![]() ![]() on the back the massive airfilters ![]() tank ![]() battery tray ![]() after all the yellow some belaz blue ![]() and, tradional for me, the last thing: The cabin ![]() Et voila. Almost completed ![]() ![]() Actually the one and only clip with my Belaz 7540 Mining Dumper working. (Don't mind the unscale Loader ![]() Here it is Now it's waiting for Spring to make a better clip and get some interieur into to the cabin. Thanks for your Interest. Maybe you'll watching my thread to build a more scale Loader ![]()
Regards Ralf |
