Old 01-14-2022, 02:16 PM
pufferfish pufferfish is offline
pufferfish is on a distinguished road
Default 1/10 Mining Dump Truck
Hi,
at first some few Words about what and why.
I've build a Russian Mining Dump Truck called Belaz 7540.
It is the smallest Model with 30 tons payload. In 1/10 that is 20KG weight and 30 kg payload.
btw: wich measurement is usual in this forum, metric or imperial?
Anyway.
Why? Simple. I was tired of my small skills in handling plastics. So i've tried to handle metal. After many errors my skills has risen and little by little i've bought a lathe and a mill for widen my possibilities.
So I've learned machining. And I've don't learned something called metal shaping. i.e. with a english wheel.
By that, I have to look for simple shaped, edgy Bodies.
And here it is
Looks simple but it will be complicated in details.
Key features: Hydraulic Steering, Rear Drive, two telescopic lift cylinders.
Latest Tool in my Shop is a Lampert M280 micro tig welder.
And now the build starts.
Fortunately i've found a very good parts catalogue with many sketches. Without any sizes but from the tire-size upwards i've take all needed sizes to start.
Material will be stainless sheet metal .3 und .5 mm thick.
First greater parts are the Backplate and the frame.
The frame are just four sheets without any additional internal structures.
Regards
Ralf
Old 01-15-2022, 01:41 AM
Default Re: 1/10 Mining Dump Truck
My simple "rules" for a all parts of a build
a) try to make on my own. if it is scale: wonderful. If not: so what.
b) if a) is negative or I'm too lazy for it: buy it.
So i've tried to made my own shock absorbers with internal springs.
The result made from aluminium. With a minimum lubrication they works as I want up to 20 kg payload. Above this they are compressed, but that will be rare moments in the life of the dumper.
on their places
Regards
Ralf
Old 01-15-2022, 09:12 AM
That's a neat looking truck.
Nice metalwork on the frame. Which welding method are you using?
Those massive shocks look really amazing.
A large portion of us use Imperial measurements, some Metric, some include both to be inclusive. Use what you're comfortable with
20kg payload dump truck is going to be a very impressive
Old 01-15-2022, 02:28 PM
It's a pulsed tig.
Originated at jewellers and dental technicians.
During a former Project i've built a hydraulic cylinder. The car isn't run anymore so i've used the cylinders body again. A hydraulic steering needs piston rods in both directions.
I convert it from
to
For scale it is way to big, but i need the diameter to get enough pressure for steering.
Parallel the work on the trough begins
the rough form is easy
but the typical beads are an enormous bulk of work
an intermediate result
50 kg / 110 lbs total weight? A usual 540 motor will be a bit overwhelmed.
From a kind hobby colleague I've get two big 24v motors with very tough planetary gearboxes.
side by side with a usual 540 with planetary gearbox
Regards
Ralf
Old 01-15-2022, 06:17 PM
Jared Jared is offline
That's some nice looking work! Looking forward to watching your build progress.
Old 01-15-2022, 10:56 PM
That's a great start to what I'm sure will be a rewarding project Ralf
Old 01-16-2022, 01:45 AM
Nice work Ralf
How do you like that Lampert M280?
I have the older version M200 and I love it.
Old 01-16-2022, 02:09 PM
Originally Posted by Hemi1966 View Post
Nice work Ralf
I love it too. It's so simple to make a connection without screws, bolt or something.
@blender: i don't have any other experiences with welding. for me the simpliest material to handle is 1.4301 stainless. and welding with additional wires are still not my thing
thereby my models are mainly from stainless
Regards
Ralf
Old 01-16-2022, 02:40 PM
rear axle. the middle piece from stainless for the flanges for links and suspension.
50 kg total weight was too much for a usual 1/10 drivetrain
but the fat wheels with their 60mm diameter enabled me to built a motor-in-axle drive
the half axles are from aluminium 50 mm od.
to compare with a usual old scx10/1 axle.
the middle part. flanges from 4mm stainless
Regards
Ralf
Old 01-17-2022, 03:12 PM
The build started in juni '21.
End August '21 i've reached a first milestone.
the trough and his bead are provisional welded
the rear axle gets her links
so the axle is mounted on the frame and a first loading test starts
pre weighed 10 kg stones
nothing cracked . the shock absorbers moves just a few mm.
20 kg stones
nothing cracked . the shock absorbers moves just a few more mm.
30 kg stones. maximum payload is reached
nothing cracked . the shock absorbers down.
some manual flexing works well too.
Now I've knew, that all the main components will work on full payload.
At this point i'm very pleased with the build so far.
Regards
Ralf
Old 01-16-2022, 11:38 AM
Blender's Avatar
Blender Blender is offline
What's the learning curve like on the pulse TIGs? Seams "easier" than tradition TIG welding, but looks can be deceiving when watching experts.
Old 01-17-2022, 06:24 PM
Very interesting build, will be quite fun to watch your progress. Sounds like you got into this hobby for the same reason I did, learn new methods and techniques. Keep up the great work and post often.
Old 01-18-2022, 03:44 PM
Indeed , thats my intension.
After this Milestone, I've got the motivation back to weld all the beads on the trough (endless small sparks in .8 second rythm) and improve the strength of the frame.
Frame and struts are real scale. Always fascinating what a few pieces of sheet metal doing with the stability.
Meanwhile the tires arrived.
Bespoked fabricated. Full, hard Rubber.
The enormous wheigth...
.... result in exact 8 kg for the completed rear axle.
I think it looks quiet nice
rims made
and a little stack of wheel caps too
As a little intermezzo the non-functional fuel-tank was done
Regards
Ralf
Old 01-18-2022, 07:02 PM
Tgrzes Tgrzes is offline
Very nice fabrication! That is one solid looking truck!
Old 01-19-2022, 12:15 PM
Thank you.
Making the front axle was much more complicated as the rear axle.
Due to the great weight i need a real brake. the esc hillbreak wasn't enough to hold the little monster. The motors in the rear axle prohibit any break in them.
Ergo the front axles must have breaks. The original has drum brakes. Consequently I plan my first drum brake in my life. That was a real exciting phase of the build.
The axles body is from stainless 30mmx3 to hold the steering cylinder, three links and the panhard. The space looks wide but, as usual, at least I've to fight for every mm.
The c hubs are made from aluminium.
All sizes and shapes, except the hydraulic cylinder, are scale.
the c-hubs gets 3° tilt to prevent understeering
Flanges are from 4mm stainless....
....or some more mm
Links done
overview and end of the simple part of the axle
Regards
Ralf
Old 01-19-2022, 06:15 PM
Nice work , you should be proud of yourself.
Old 01-20-2022, 12:33 PM
Thanks. I am
The complicated parts of the front axles needed intensely research and planning time. Enough time for painting. Not my favourite task. But sometimes it has to be
Bored from painting, i've made the baseplate for the Front
(1mm stainless)
Planning has closed and the work begins.
Milling the Joints from stainless
After some tests about steering radius etc i've to shorten the steering cylinder. So i've take the opportunitiy and build it a bit more scale. later you will see nothing from it, but i know, it's almost scale.
changed cylinder needs a changed flange. from
to
at least mounted and covered from a heavy duty skid plate
Regards
Ralf
Old 01-21-2022, 06:58 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
I always enjoy seeing machine work photos, especially like seeing the work holding solutions. Jim
Old 01-22-2022, 12:31 AM
Drum Brakes.
some stainless sheet , 3mm thick, aluminium for the drums and some 6x1 stainless pipes
the square sheets are turning into round and welded together with the pipes
welded onto the joints
first tests. all things going well.
i need stops on the axles to prevent the drum from contact with the baseplate
a lack of suitable stainless washers forces me to made my own
small pieces of a 1mm sheet
turned together to the od
et voila
welded on position
in the their front , the drums has holes to hold two bearing and a spacer.
in the back the big hole for the brake pad holders
put on the axle, the drum fits well and has no contact. the double bearings are strong enough to avoid tilting.
A good start into this chapter.
Regards
Ralf
Old 01-22-2022, 03:05 PM
Drum bakes: Brake pad holders.
aluminium round
simple method to hold the round parallel to the middle
sawed and milled
brass bolts
fitted with springs
set up
a little problem are the brake pads themself. after a lot of research i've found the tip that gasket paper (abil eg) was a pretty simple material
and really: it works perfect.
mocked up
next and last part: bowden cable and the mechanics to activate the breaks.
Regards
Ralf
