Old 06-24-2011, 01:34 PM
Default Re: CAT 14M Motor Grader
Originally Posted by JensR View Post
That looks great!
Is the outward connection of the side shift is not outwards enough, it looks like you have only relatively little movement to the right?
In the original, the brackets sit much closer to the end of the blade.
Is this a restriction because of the hydraulic cylinder?
The movement is actually made by electric motor and spindle, and that restrict the travel. The short travel (35mm both ways) annoys me too, so I´m going to change the spindle to hydraulic cylinder.
