Old 06-28-2011, 04:25 PM
Default Re: CAT 14M Motor Grader
Ari, thanks for the technical info about the cylinders. Those inside-cutting tools are really small, but just right for what you are making. Is the rod and barrel material stainless steel? Piston? Maybe I'll try making some cylinders now.
Thanks again.
Old 06-30-2011, 04:03 AM
Thanks again.
The rod is stainless steel, but the barrel and piston are made of aluminium.
Past few days I´ve been making the centershift cylinder, and the blade lift cylinder holders.
Next I start to make the blade lift cylinders
