Old 03-04-2013, 08:09 AM
JDH429's Avatar
JDH429 JDH429 is offline
Default Re: Finally done peterbilt tri-axle dump! update 1-5-13
Can I ask about size of material you used to build your box? The plate for side walls, plate for front outer skin on the box? And the verticle side posts on the outside of the box? looks bigger than 1/4" square. Are those solid alum square stock? How about the under frame of the box which looks Killer btw. Thanks!
