Old 03-04-2013, 08:09 AM
JDH429's Avatar
JDH429 JDH429 is offline
Default Re: Finally done peterbilt tri-axle dump! update 1-5-13
Can I ask about size of material you used to build your box? The plate for side walls, plate for front outer skin on the box? And the verticle side posts on the outside of the box? looks bigger than 1/4" square. Are those solid alum square stock? How about the under frame of the box which looks Killer btw. Thanks!
Old 03-10-2013, 05:29 AM
Brian in PA's Avatar
I'd rather be truckin'
Originally Posted by hammer View Post
Brian,
Once again another beautiful machine you truly are the king of tri axle dump trucks don't think there is another truck out there except for your green one that even comes close awsome job.
Tony
Thanks Tony!
Originally Posted by Dreamweaver View Post
Another Masterpiece Brian. Love the colors... Heck love it all!!
Thank you Mike!
Originally Posted by JDH429 View Post
That is unreal! A real inspiration for someone looking for ideas. Thanks for sharing!
Thanks!
Originally Posted by Azorean View Post
AMAZING, JUST WOW...
Thanks!
Ill have to check on the thickness for you, its about a 32nd or so. The posts are actually brake formed outer skins with 1/4 inch stock under them. The frame is also 1/4 stock. Thanks!
Brian
Old 03-10-2013, 07:58 AM
Clint307's Avatar
Clint307 Clint307 is offline
Clint307 is on a distinguished road
That is a really sharp looking end dump Brian! Super fancy!
