Old 07-30-2013, 04:25 AM
Madda Madda is offline
Madda is an unknown quantity at this point
Default Re: CAT 374D L
Originally Posted by Hemi1966 View Post
I can get under ±0,02mm tolerances when everything goes perfect
Wow, that is really tight
Do you have so perfectly configured/modificated machine or you have some trade secrets that you use to get that tolerance? I can get something about 0.05mm usually on my parts, if all goes well it is sometimes even 0.01mm, but it really varies on part to part.
Old 08-04-2013, 03:32 AM
I have ball screws in all axis and the cross table dovetail guides relatively tight to have minimum play.
I also make several final passes to compensate tool flex.
But like you said it won't always go so well in every parts
Old 08-04-2013, 04:13 AM
Some painted parts
