Old 07-29-2013, 02:00 PM
Default Re: CAT 374D L
Originally Posted by Madda View Post
Beautiful job, can't wait to see the final product!
Ari, when you make parts with your BF20l, what tolerances do you get usually on the parts?
I can get under ±0,02mm tolerances when everything goes perfect
Old 07-30-2013, 04:25 AM
Madda Madda is offline
Madda is an unknown quantity at this point
Wow, that is really tight
Do you have so perfectly configured/modificated machine or you have some trade secrets that you use to get that tolerance? I can get something about 0.05mm usually on my parts, if all goes well it is sometimes even 0.01mm, but it really varies on part to part.
Old 08-04-2013, 03:32 AM
I have ball screws in all axis and the cross table dovetail guides relatively tight to have minimum play.
I also make several final passes to compensate tool flex.
But like you said it won't always go so well in every parts
Old 08-04-2013, 04:13 AM
Some painted parts
