Old 12-19-2013, 02:15 AM
DADSGARAGE's Avatar
Default Re: 777 HAUL TRUCK (1/12 size)
Pics of the solid rear axle ( no diff. time will tell how it steers )
Shaft c/w flat and 1/2" NC threads
[/IMG]
Rear duals on shaft
Drive plate c/w flat to match shaft
Add spacer to cover the nut
Finished assy. c/w covers
Old 12-19-2013, 02:18 AM
DADSGARAGE's Avatar
OOPS try again.... here is the first pic
Shaft c/w flat and 1/2" NC treads
Old 12-20-2013, 06:59 PM
DADSGARAGE's Avatar
First try using this type of steering control ( this one did not work needed some changes )
Used a Hitec 785 winch servo ( 3.5 turns) and a 12T sprocket ( servo city)
http://www.servocity.com/html/32p_hitec_metal_gear.html
Old 12-20-2013, 07:07 PM
DADSGARAGE's Avatar
Drilled and tapped holes in the strut shafts to attach the steering contol arms
(cut from 10ga)
Old 12-20-2013, 07:22 PM
DADSGARAGE's Avatar
Needed to get this thing on all fours...or should I say six....
Cut the bearing hubs off the cheap rims that came with the tires , then made simple front hubs for testing this thing out...after welding they got faced off , drilled and reamed for some bushing. I hope to make some better front hubs with ball bearings later on (but most likely I will use these for a long time..LOL)
Old 12-20-2013, 07:52 PM
DADSGARAGE's Avatar
Steering design...take 2....
Really wanted to have this all in the body and not under the truck but for now it will work...don't even know how or if this idea will work, needed to do something to test it all out.....(hopefully it will have enough torque for this heavy model)
