Go Back   RC Truck and Construction > RC Truck's Ag and Industrial Equipment and Buildings > Construction Equipment > Construction News
Construction News New kits & accessories offered in the world wide marketplace
Old 12-28-2013, 02:30 PM
JohnStilwell's Avatar
JohnStilwell JohnStilwell is offline
JohnStilwell is on a distinguished road
Default Re: RC4WD Loader
Well, from what I have seen in the video, they are having problems with the front drive. Seems the drive for the front tires does not want to work some times. You'll see it in the beginning when he first backs up - rear tires dig a hole, fronts are not driving, you can see both front tires, so I know it's not just a differential thing. You know something's up because he stopped for a second too, for no reason. Watch again carefully and you'll see other times the front drive isn't working, a slight jerkiness to the movement, probably why he's going so slow too. As said, those axles aren't going to last long either pushing 5" plus tires!!
I'll pass!!!
John
Old 01-02-2014, 11:29 PM
der82c der82c is offline
der82c is on a distinguished road
I'll pass!!!
John
its still a differential axle without locking. that is why sometimes left wheel is not turning as the differential gear had transfer the turning to right side wheel. will one the taiwanese had post some work sheet. the rim hub are built in planetary gearer system cause the slow travel. however, i think itself do not have enough weight to press itself grip to the earth.
Old 01-15-2014, 08:26 AM
A1 Dirt A1 Dirt is offline
A1 Dirt is on a distinguished road
It's on the RC4WD site, but listed as "Out of Stock".
http://store.rc4wd.com/112-Scale-Ear...er_p_3828.html
Old 01-15-2014, 09:44 AM
It "looks" good. I like that it is big and heavy too. Hopefully having planetary axles will help keep those center sections together cause they sure look small between those tires...
