Old 12-30-2013, 09:05 AM
kaptain Jack's Avatar
Default Re: Bruder D11
Looking good.Have you tested the range of motion? Is the servo strong enough?
Old 12-30-2013, 11:30 AM
motocrawler motocrawler is offline
motocrawler is on a distinguished road
The range of motion is perfect, it travels exactly to the physical stops/limits on the model. I am using metal gear servos on each side so it is plenty strong it has an approximate combined torque of almost 100 oz/in.
Old 01-03-2014, 04:59 PM
I didn't like how the tracks had no rollers/bogies so I cut out the faux rollers and made some rollers.
Old 01-03-2014, 05:05 PM
I used a metal gear servo for the blade tilt
From there I added some LED's
Old 01-03-2014, 05:14 PM
Here is a shot of the guts, the semi circle pieces are wheel weights I had kicking around from 2.2" proline tires, they are zap strapped together and held down with heavy duty double sided tape. I need to put it on a scale but with the battery in it definitely has some weight behind it now.
Old 01-03-2014, 05:20 PM
So I got the dozer almost done. I decided not to automate the ripper as I have my doubts about the tracks holding up to the strain of ripping. I want to test it first and perhaps add some different grousers. I need to make the orange flashers and clean up some wiring and painting/weathering and it will be fully done. In the meantime here are some almost finished photos.
Old 01-03-2014, 05:22 PM
Here is a test video of it. Just need the monsoon rains we are getting in Vancouver to subside so I can get some actual working footage of it in the dirt.
Old 09-16-2017, 12:35 AM
A GREAT idea
