Truck Building Tech Covers mechanical and electrical components for truck modeling |
I use 10/32 in all of my builds but the dump trailer and it is 3/8 fine thread. The dump trailer was my first screw drive and I did not think about the fact that the sliding block would carry the load and the all thread just had to move it. All of my screw drives push from back to front. For gear reduction my traler is 32:1 with a 65 turn 540 lathe motor the two dump trucks are 50:1 carson gearmotors and the dump pup trailer is a black & decker $10 screw driver from Wall-Mart.
![]() Travis Quote:
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
IHSteve
Thanks guys, that helps a lot. I have a large sheet of paper in front of me right now and trying to put this down on paper. I've got the Rod thrust bearing and a piece of nylon for the slider and I'm just figuring out the length of the push rod. Looks like it's about 8". What's the normal tip angle for the box to empty, I've used 45 and hope that's high enough. I think now that I should have waited before I ordered the gear motor. I only ordered a 34 rpm and it's going to be way too slow. Look like it would be better in the 150 rpm range. Anyhow, thanks again for the help as I'm getting more on track.
![]() Rob |
