Old 01-12-2014, 01:23 AM
dabears's Avatar
dabears dabears is offline
Default Re: My Stretched globeliner
Originally Posted by buzzy16 View Post
This is an awesome truck you've got here. How exactly did you set up the charge ports? It's a great idea
Thanks buzzy
Sorry for the delayed response.
First buy a 3 position switch (3 pole) should have 6 contact on top.
You wire the battery to the middle 2 terminals poss on one side and ground the other.
wire a blank set of wires with a plug on it to one side matching poss on same side etc.
the other side is wired too the mfu power wires. its a reversed switch basically you click the switch right it sends power to left terminals. switch left sends to right terminals. center is off.
Not sure how well you can see but here is the switch wired up. I have a 8" lead with deans plug at end running thru cab floor above my right tank. I can reach it under the tank and pull it out a little to charge and then push extra wire back up into cab floor when running and stays out of way...
Let me know if that helps. if not I can draw it out in paint or on the photo or take different photos.
