Old 01-13-2014, 07:49 PM
Default Re: New member. Building D8
A bare stock will pull it ok, but at least 3:1 additional gear reduction would be better control. Lock the rearmost axle.
Old 01-14-2014, 07:51 AM
Fired up Fired up is offline
Fired up is on a distinguished road
How do you lock the rear axle the gear reduction is that from rc4x4 ?
Old 01-14-2014, 12:02 PM
I am building this project as cheap as I can here's the first axle. Using threaded rod with long nut on each end passing through 1/2 by 1/2 square tubing
Old 01-14-2014, 12:07 PM
Here's anther view of axel. Like I said building this as cheap as I can I am make the wheels out of hockey pucks turning them on my lath. Still thinking of how to build the goose neck.
