Go Back   RC Truck and Construction > RC Truck's Ag and Industrial Equipment and Buildings > Construction Equipment > Construction News
Construction News New kits & accessories offered in the world wide marketplace
Old 01-15-2014, 10:55 AM
dabears's Avatar
dabears dabears is offline
Default Re: RC4WD Loader
•CNC machined aluminum parts
•Molded steel bucket
•6 channel 2.4Ghz radio
•Optimized steel hydraulic system
•Scale operator station (can fit a driving figure)
•Massive 29.5-25L-5 tires
•Reliable hydraulic valve and adjustable pump
•Heavy duty hoses (OD 4.5mm Nylon, ID 2.5mm)
•Powder coated in yellow
•Brushless system (hydraulic)
•40A brushless ESC with BEC
•XXX Kv brushless monster torque motor
•Realistic non functional disk break
•Scale ABC plastic interior
•Wheel with planetary gearbox build-in
•2 speed full metal transmission (1:16 and 1:4 gear ratio)
•Realistic fullfull metal axles
•Run time is: XX minutes (XXXXmAh battery)
•Steel machined oil pump (45mm X 30mm X 15.5mm)
•Bucket capacity:
•Maximum bucket force: 70kg/154pounds
•Driving speed: XXX meter per hour
•Scale: 1:12
•Length: 741mm/29inch
•Width: 276mm/11inch
•Height: 276mm/11inch
•Maximum bucket height: 461mm/18inch
•Maximum bucket up and down angle: 46 to 64 degrees
•Maximum bucket left and right angle: 38 degrees
•Wheel base: 284mm
•Deadweight: 20.5kg/45lbs
•Total mass load: 32kg/70lbs
•Operating oil pressure: 20Bar, 290psi
•Manufactured by JDCustoms
•30 days limited warranty
$450 shipping charge!!!! WTF!! 100lbs shipping weight!!! says its a 1/12scale don't like the looks of the trans, axles look like truck axles and whats with the fron disc brakes?
Ill hold out for the Wedico one I dream of owning one day!!
Old 01-15-2014, 12:17 PM
MoRockN's Avatar
MoRockN MoRockN is offline
MoRockN is on a distinguished road
I'm sure they'll sell a ton of them to the Right customers. If it was 1/14 scale and $2500 I'd buy one just for the heck of it. but 1/12 scale and $3200 is making it out of the picture for me since I already have a loader. I know it's "crappy" for the most part but remember it is ready to run. By the time me and Eddie got our loaders working the way we want them to be with the right radios, quick couplers, buckets, servonaut sound, ESC, BMA , lights and such and the countless freaking hours spent to get them working and dialed in we're well over $8000 in + shipping and payment fees. Trust me, waiting for stuff for 5-6 weeks at time makes this loader a much better option for people that don't like to tinker and wait, Not to mention almost half the cost. Which makes it hard to part with our loaders and people just don't understand that a wedico loader for $5600 still needs almost another $3000 to make it sweet.
If you got it, a Trucker brought it....
Old 01-15-2014, 11:46 PM
dabears's Avatar
I see what your saying. And that's what is nice about this place. many have tested and re worked a lot of things to be able to know what it takes to be "right". I can see the $3200 price tag nice for some but id go with a $8k Wedico that works right and will last. Not that this one wont just my preference I guess. I guess if it was 1/14 scale id have different feelings about it
Old 01-16-2014, 05:27 PM
MoRockN's Avatar
Very well said buddy. Same with my truck I got from them, I had to take it apart and rework it to make it right.
Old 01-18-2014, 05:35 PM
pigeonfarmboy's Avatar
Don't be too naive Aaron. Have any idea how much stuff myself and others had to rework on the Wedico 966 to "make it right"? Probably just as much if not more than it would take on one of these. I'd say the Liebherr 576 Loader is as close as anyone could get for the highest grade kit offered at this time. Even ScaleArt stuff needs a bit of debugging to get them just right. The hydraulic system is pretty solid (but Wedico doesn't make that part).
I was extremely surprised to see the cost of this kit exceed the excavator. Must have had more development costs considering a loader is a less complicated machine. Especially since they used some existing components from the dumper.
I wish they would state if the axles are locked full-time or are lockable via remote channel.
Old 01-22-2014, 03:44 PM
MoRockN's Avatar
They're cable lockable Nate. One thing I can tell anyone that's gonna get this loader, those axles are NOT very smooth, so keeping them locked is best since when they're open they "hop" or grind when they're new, until you get them broken "IN" they will seem like they're stripprd.
