Truck Building Tech Covers mechanical and electrical components for truck modeling |
thanx im gonna buy the turn buckles. how would you suggest i connect the chain to the turn buckle by screw and nut!!
Grabbin gears and Rollin wheels ! LETS BLOW SMOKE!! Member of the Central Plains Mini Truckers,and a Minnesota road hammer. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Flat bedders do it with chains and straps,but now im yanking 53's To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
![]() Travis
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
Have you guys got any tips for gate locks on dump boxes. Finished up the the screw drive and dump box, just trying to figure out how to lock the gate.
Thanks Rob |
rob , here's what I did
![]() this is the lever that closes the latch when the bed comes down to rest on the frame . It takes some tweaking till you get it right , but it works like a charm ![]() ![]() lets see if the vid works ( i can't remember what the squeaking is ![]() ![]() IHSteve
IHsteve. Thanks for that. Here I am thinking about servos and screw drive latches and sometimes a person works himself into a corner. That catch, you built is great and if you don't mind I'll change it a little bit and try to make one like it. The way it opens when the box lifts is what I'm looking for.
![]() Rob |
no Problem Rob , I tend to get a little suffisticated myself
![]() ![]() IHSteve
