Old 01-16-2014, 06:23 AM
Fired up Fired up is offline
Default Re: New member. Building D8
I am going to put a new duel speed control in my king haule and was wondering if I could use a 12amp in it or should I go with the 25amp. Any suggestion
Thanks
Old 01-16-2014, 07:35 AM
12amp should be fine. I use a Sabertooth 2x12 in my 850 Kenworth and it only overloads it while in high gear towing a load. The truck is around 100 pounds at that point.
Old 01-16-2014, 09:57 AM
JAMMER JAMMER is offline
Very nice work it's coming a long nicely. Ed
Old 01-20-2014, 04:05 PM
Ooh look what came today.
Old 01-20-2014, 04:43 PM
Any suggestions on how to hook everything up. Do I need an air relief on tank?
Old 01-21-2014, 07:57 AM
Looking for a hand in hooking my hydraulics. First question is my valve bank has holes on each end straight through. One is for return to tank and other from pump. Do I put both lines on one end and plug the other end or do I put line from pump on one end and return on other end on opposite sides? Any help would be great thanks Patrick
Old 01-21-2014, 06:06 PM
I had some time to play today. I started to get my hydraulics put together when I tried it I blow a line. I came to the conclusion that I may need a relief valve. I am not able to run motor steady with out it blowing a line. I assume it because of no relief valve.
