Old 01-16-2014, 09:57 AM
JAMMER JAMMER is offline
Default Re: New member. Building D8
Very nice work it's coming a long nicely. Ed
Old 01-20-2014, 04:05 PM
Fired up Fired up is offline
Fired up is on a distinguished road
Ooh look what came today.
Old 01-20-2014, 04:43 PM
Any suggestions on how to hook everything up. Do I need an air relief on tank?
Old 01-21-2014, 07:57 AM
Looking for a hand in hooking my hydraulics. First question is my valve bank has holes on each end straight through. One is for return to tank and other from pump. Do I put both lines on one end and plug the other end or do I put line from pump on one end and return on other end on opposite sides? Any help would be great thanks Patrick
Old 01-21-2014, 06:06 PM
I had some time to play today. I started to get my hydraulics put together when I tried it I blow a line. I came to the conclusion that I may need a relief valve. I am not able to run motor steady with out it blowing a line. I assume it because of no relief valve.
Old 01-21-2014, 06:14 PM
Yes you will need a relief valve for sure.
Old 01-21-2014, 09:12 PM
Ok that's what I thought. With the relief valve pump will be able to run continuously? Thanks for the help.
