Old 01-19-2014, 08:47 PM
DADSGARAGE's Avatar
Default Re: 777 HAUL TRUCK (1/12 size)
Thanks Jammer.....using air filled tubes on all six tires would be good, the problem is in hiding the valve stem on the rear outside tire....rather not see a valve stem on the outside....the rims are two pcs and must be mounted before adding air, and there is no room to get at the valve stem between the duals if I put the valve stem toward the inside between the duals....hopefully the "racquetballs" will work instead of a tubes on the outside duals, time will tell......
Old 01-19-2014, 09:01 PM
DADSGARAGE's Avatar
Cut a few more parts......
- the mount plate for the two ESC's (one for the drive motor and one for the linear actuator to lift the box)
- bearing support parts for the 1/2" output shaft on the gear box
