Old 01-24-2014, 06:42 PM
Lmackattack's Avatar
Default Re: Dozer questions
You should try to power both tracks from the same end. You may find it will "walk" side to side when trying to go forward or backwards...
If by chain your talking the tracks....real dozers use a idle wheel at the front. Grease is pumped into a chamber that pushes the idler wheel forward and thus makes the tracks tighter helping prevent them from jumping a tooth or completely falling off the sprocket.
Old 01-25-2014, 05:28 AM
buzzy16 buzzy16 is offline
buzzy16 is on a distinguished road
Thank you for replying, I thought I'd better ask that before I made any plans on where to place the motors.
So where a lot of the guys use springs to tension the idler wheel you can use grease instead.
