Old 01-26-2014, 08:07 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Re: Marion 182M Stripping Shovel
Tom,
Thanks for the pictures! Did you do a build thread during construction?
Can you tell me more about casting the track pads? I wonder if I could use lead and if the heavy weight property would be any advantage for a crawler undercarriage on a dozer?
Jim
Old 01-26-2014, 10:41 AM
JAMMER JAMMER is offline
Tom thanks a lot for the pictures I really appreciate them. Ed
Old 01-26-2014, 03:41 PM
modelman modelman is offline
Originally Posted by Rvjimd View Post
Tom,
Jim
Hi jim-I did do a build thread on the "garden trucking" site. The pictures were lost when they shut down. Casting the pads were easy but making the master part was the hard part. It took about 15 different set-ups and-2- weeks to make the master part (I work slow). I knew I could never mill out al those pads and make them accurate and I wasn't going to spend a year milling tracks. Lead might work but it is really soft and I think the pins would work loose over time (just my opinion). The epoxy works fine for a shovel because they do not use the tracks that much. On a dozer probably not. So the problem with making tracks goes on. I can tell you a lot about casting some parts from epoxy if you want. Just let me know.
