Old 01-29-2014, 08:38 PM
Default Re: New member. Building D8
Pretty good speed up/down, higher pressure might increase it somewhat, but it looks to be close for acting quick enough while pushing. Good work!
Is that a 3s or 4s lipo in the 1st vid? What's the brand name?
Old 01-30-2014, 03:50 PM
Fired up Fired up is offline
This is what I was running pump with I bought it to run track motors I might use the same for pump. Or go to an 18v like Greg uses in his. The speed was good and that was with pump not running at full speed. At around 20 bar like you suggested. I need to look at sizes of 18 v battery as it's very tight for space. Is it ok to run pump at slower speeds? Or should it run at faster speeds when pump is working.
I have striped the dozer down and started to paint it. I have a few things that I need to make for it like the track bed. Windows and some other small details.
But it's coming along nicely.
Thks for looking and all the help.
Patrick
