I have seen timing chain tensioners used that simply apply pressure on the chain with the use of a slippery plastic. However you may need to use a threaded rod on that idler gear as you won't have a constant source of lubrication. Maybe a hydrolic type tensioner pushing on the idle gear bracket?
