Old 02-05-2014, 08:46 AM
ihbuilder's Avatar
Default Re: 777 HAUL TRUCK (1/12 size)
Dads , how well does that H2O jet cut gear teeth ?
777 looks great so far
Old 02-06-2014, 10:19 PM
DADSGARAGE's Avatar
Seeing what you're creating from the use of a waterjet table vs the usual cnc works is quite amazing! What's the ballpark $figure for such a tool?
An "OMAX" 55100 waterjet table retails for about 200K US$
The waterjet does a great job cutting "straight" gear teeth profiles , all the gears I have cut have been used "as is" after cutting on the table short of doing some filing, but if you needed a high precision gear it would be best to cut the gear blank slightly bigger and then use the proper gear cutter to finish it...
Thanks !!
Old 02-06-2014, 10:36 PM
DADSGARAGE's Avatar
Got the radio gear installed ......finally .....hope to have a video posted soon of the test run
Need to finish welding the box frame and then add the box panels....floor sides etc...
Old 02-06-2014, 11:33 PM
DADSGARAGE's Avatar
TEST RUN VIDEO
https://www.youtube.com/watch?v=tzh2...cnElm7fYjN3bEA
Old 02-07-2014, 02:26 AM
Well almost done, eh? Weld up the box, give it a coat of paint & you're off to the races!
Lucky you! my combine costs nearly triple that, but I don't get to use it for my hobby too.
