Hi did you cut all the internal and external gears in you drive? If you did you did a very nice job. Ed
Hi Ed,
just the internal gears are laser cut. In every drive is a stack of 10 sandpaper-cleaned pieces with a complete height of 20mm. Using thicker material is less/ poor quality. The internal gears were bought online. Sorry for the blurry picture, it shows one of the int. gears. The small brass gear was just for checking. |
Hello so you laser cut the internal gears, I was thinking you cut then your self and was wondering how you did it. Your way is a lot easer than broaching them and also buying the other gears saves a lot of time but you still did a nice job. Ed
Ed, stay tuned! I'll come up with the turntable next. It has an internal gear, also, but bigger teeth and wasn't lasercut
OK I sure will be looking forward to that. Ed
Hi folks,
here now the (original built) turntable. It has an internal gear with 107 teeth, modul 2. This gear are two parts, every one got a radius on the edge for the 5,5mm steel balls. The gear is bolted to the gear carrier with 48 screws. Then there are two outer rings with a radius for the balls, also. They are filled with 135 balls and then evenly closed with 3 screws. The upper body of the excavator will be bolted with 45 screws to the turntable. The internal gear was done by my buddy Michael on his cnc-mill with a 0.4mm endmill. The screws were made by myself, 96 pcs for this turntable and 288 for the Michaels turntable for the R9100. As I mounted the stuff together I found out, that the turntable need much power for turning, so I had to improve. With a sharpie I colored the ball groove and used a 5.5mm Drill shaping the groove with the drill flange, about 3 or 4 times. Now it runs smooth and without any play. |
here are some selfmade screw-pics:
