Fire and Rescue and Emergency Vehicles Here is a spot for all them important emergency vehicle builds. |
Fill the roof in
![]() ![]() Time the the wheel opening ![]() ![]()
Need to lower the side window
![]() ![]() Fill in the grill and cut the body to fit around the frame. ![]() ![]()
I got the new frame done this weekend and I also put 2 globliner floors together so i could mount the cab. Now to finish the windows on the cab and the front bumper then on to the back half.
Ok guys here we go again I have 4 days to get alot done on this so here we go. [smiley=thumbsup.gif]
I cut the last windows and layed out the doors I also made temp lets so I can cut the door out of very thin plastic to do over lay for the door later. ![]() Next to start on the back of the body. I am using 1/4 PVC sheet for the inner frame work of the body then I will cut and bend the PMD alum tread plate and plan alum sheet and line the bed of the back. ![]() ![]() ![]() Ok back at it I will up date later again. [/b]
Ok last night I finished the pump house boxing it in and I added the vents on each end of the unite on top of the pump house.
![]() ![]() Then i had to cut 1 1/4 off the frame as I messed up a little and had to add the back step but no biggy was not too tuff to fix. ![]() Next I had to make the side with the roll up doors. They just look like roll up doors but dont. The hole side of the truck is hinged to flip the side down for wiring later. ![]()
![]() ![]() ![]() ![]() ![]() [/b]
