Old 02-13-2014, 02:07 PM
Markus K. Markus K. is offline
Markus K. is on a distinguished road
Default Re: 1/10 Liebherr Excavator R 984 Litronic
Thank you, Ed. No problem with any suggestion or different fabrication methods, this could bring some new ideas for following stuff. So they are very welcome! But in this case I want to do it scale and the cylinder can be opened by removing the (again selfmade) hex-bolts M3 from the head.
This pictures shows the rod at the piston end. It has a diameter of 16mm and received a M10 thread and a groove for the gasket. The piston was finished directly mounted on the rod for 100% center fit. After all I think the loctite on the thread should be enough to seal the rod and piston, but the o-ring can't be bad, either.
The bottom parts of the cylinder were silver soldered, because there wasn't a area big enough for soft soldering. To avoid desoldering of the cylinderheads i put them upside down in a small bucket of water.
Old 02-13-2014, 02:13 PM
JAMMER JAMMER is offline
Thumbs up Re: 1/10 Liebherr Excavator R 984 Litronic
Markus very nice work on the cylinders. Permatex has a special compound for sealing cylinders and hydraulics I use it all the time and it works real good. At the moment I do not have the number for it but if you want it I can get it for you. Ed
Old 02-13-2014, 02:25 PM
Then the tube needed a clean-up. For this i made a simple 4 jaw chuck, whitch worked really fine for this light cut. After this i made some brass cubes for connecting the pipes. Again I made a little tool to chuck the square stock centric in the 3 jaw.
Ah, Permatex! Amazon supply this stuff in Germany. I'll take a try on the cylinders for the next model.
Old 02-13-2014, 02:40 PM
There are more pictures from the cylinders, so here we go. Pic 1 and 2 is the bucket cylinder (equal on the R984 and the R9100). Pic #3 is the stick cylinder (single on the R9100 with a much bigger diameter, 30mm bore and 18mm rod), pic #4 is a hoist cylinder for the R9100 and the last pc shows the front end of the R984-hoist cylinder in detail.
Hope, those many pictures are not boring you guys!
Old 02-13-2014, 03:02 PM
Ah some more of you excellent work. The tube bending is hard I have done some on my excavator. Ed
Old 02-13-2014, 03:33 PM
I just found out, that there is no picture in my album just showing a completed cylinder, anyway, here a last pic for now from the cylinders.
Then I wanna continue with some railing work i did for both excavators. It´s all brass tubes with 4mm diameter, just the same as for the hydraulic pipes. The railings in the last 2 pics belong to the R9100. I used a small tube bender and a microflame to heat up the pipes before bending. That makes the brass soft.
