There are more pictures from the cylinders, so here we go. Pic 1 and 2 is the bucket cylinder (equal on the R984 and the R9100). Pic #3 is the stick cylinder (single on the R9100 with a much bigger diameter, 30mm bore and 18mm rod), pic #4 is a hoist cylinder for the R9100 and the last pc shows the front end of the R984-hoist cylinder in detail.
Hope, those many pictures are not boring you guys! ![]() ![]() ![]() ![]() ![]() |
Ah some more of you excellent work. The tube bending is hard I have done some on my excavator. Ed
I just found out, that there is no picture in my album just showing a completed cylinder, anyway, here a last pic for now from the cylinders.
Then I wanna continue with some railing work i did for both excavators. It´s all brass tubes with 4mm diameter, just the same as for the hydraulic pipes. The railings in the last 2 pics belong to the R9100. I used a small tube bender and a microflame to heat up the pipes before bending. That makes the brass soft. |
